Rog, Had it off the engine so I didn't need to, Thanks
F115 synchronization
Originally posted by rodbolt17 View Postyep
but sometimes you must touch the so called tamper proff non-field adjustments.
however ONLY when you isolate that it is the issue.
usually it is a running issue that causes the intake vacuum not to sync.
(before I had the tool).
I later found the shop, ADJUSTED the painted(don't touch) screw for the sync (easier to get to than the AIR SCREW). White paint on the screw, BROKEN, was the "give away".
Set that back to where it needed to be and then I adjusted the air screw for the sync... F..ed up, pay $125 for a shop to screw up a simple sync.
BTW, they couldn't find the issue. The issue was found with the help from an FJR forum I frequent (common issue with that year)..
.Scott
Yep, that's exactly what I did. Thanks for the info Townsend I'll be back on it next week. I know the boat was at the dealer before I bought it for water in the fuel issue. Wondering if those guys played with the "do not touch screws". I'll keep you guys posted.
ÂÂ
