When running the engine after changing the impeller I noticed that there was water coming out where I don't remember it doing this before. This is only the second time I've run the motor out of the water. Water is coming out of the front just above the lower unit and out of what must be weep holes on the back side of the lower unit. I'm getting good pee water out of the head. pix included. is this normal?
I also put a little bit of lithium grease on the 4 bolts on the impeller housing body and the 4 bolts on the lower unit. Was that a bad idea?
Thanks,
Bob
Thanks,
Bob
