dude
put the meter down.
do a bit of reading on what voltage is, what it does.
read what current is and what it does.
from the blue wire at the pump to ground at the block you should read battery voltage,almost.
when you toggle the ground switch it should drop to less than .5V.
if it does not drop, fix the ground path.
remember there are a few splices in the harness for + path and - path. voltage is a simple measure of electrical pressure.
current makes it move.
put the meter down.
