I have just read that one is suppose to flog the engine by using a small gas tank with the flogging additive added. Is this correct? I have used the spray in the intake port but is this wrong? If the small tank is to be used and run for 10 minutes where do you attach the hose to? Any reason not to simply use the spray?
flogging 2012 f90 4 stroke 90hp
Originally posted by rodbolt17 View Postcause you simply cannot spray and make the spray run up the top 3 intake runners.
that is why we fog with a fuel mix.
a mule we may flog.
You silly boys!!!!! The OP probably didn't even see that he had a word use problem there. A mule you usually hit upside the head with a 2X4.Dennis
Dennis
ÂÂÂÂÂÂÂÂ
