Did you not have trouble with the float and needle in a separate post awhile back? I wonder if that float is still not right and sticking....
Also make sure the fuel tank is venting properly (I am assuming you are using a 5 gallon portable tank) You can loosen the cap while running and the engine is acting up, see if it starts running right.These new tanks only vent one way and that sometimes don't work right.
Seems strange that it will run good when warmed up but keeps cutting out when it is cold...but now you say it is losing power at WOT as well....
What kind of boat is it? Could not see the whole thing in your video.
