Originally posted by 99yam40
View Post
Another forum and member suggested instead of the separate tank fogging mixture to empty the water separator fill back up with 1/2 fuel & 1/2 quality 2 stroke oil and do the same to the fuel cup before the VST.
procedure suggested;
"remove the water separator on the boat , dump the gas out if its a large yamaha style just dump half , fill it with decent 2 stroke oil and put it back on. pull the small fuel filter housing on the engine and dump the gas out. refill with 50/50 mix gas and 2 stroke oil. set up your muffs and bucket with -50 anti freeze about 4-5 gallons , start and run the engine and increase speed to about 1k. it will start and run then start smoking , as the anti freeze runs down rev it up and down just a bit to increase fuel flow and smoke. You may or may not use all the anti freeze but when you start getting it out the tell tale and exhaust you should have enough."
Anyone ever try that method. Just a thought because I am not sure I would burn all the fogging mixture in a separate tank and have it sitting around for another year to store and not be able to get rid of.
Leave a comment:
