Was removing a brass main jet on a Yamaha generator and it broke in pieces. Seemed like it was soft. Ethanol fuel related?
Jet destruction
if there was corrosion sticking the jet due to water in fuel, ethanol could have pulled water from the air.
but ethanol itself does not attack brass as far as I know
I worked on a commercial Yamaha powered pressure washer that wouldn't start. (clogged carb from sitting).
The carb was a high end unit (Mikuni maybe, been awhile) and pulling the brass main jet was a bear.
Had to clamp the carb in a vise, grind down the SIDES of the exact sized screwdriver. Soaked in PB Blaster.
W/O using a hand held impact, it did come loose with all the force downwards and turning force I could muster.. The jet itself didn't seem softer than normal, just installed SUPER TIGHT...
*Agreed with below posts, I doubt ethanol had anything to do with it.
I pull jets (similar very varnished up) all the time and that Yamaha was DEFINITELY the hardest to remove (and there wasn't any visible varnish on the threads)...
I suspect someone in the Yamaha assembly plant is "very heavy" with the screwdriver when assembling...
.Last edited by TownsendsFJR1300; 10-22-2017, 07:00 AM.Scott
ÂÂÂÂÂÂÂ
