Hello All,
This is my first post after finding this board while researching the issues I am currently having with a 2009 Sea Hunt Triton 240 with a single 2008 Yamaha 250, fly by wire throttle and 2 square command link gauges. While cruising in smooth water, the gauges all work fine. Once I am in waves, my Command Link gauges intermittently drop the MPH, RPMs, oil pressure, temp, and voltage. The trim gauge and fuel gauge never drop out. I have checked the connection entering and exiting the bus port/bar feeding both command link gauges. I have checked what appears to be the wiring harness connections at the motor. No corrosion or loose connections found. The bus port/bar was replaced as the issue, however it is still occurring as of yesterday.
Is there another connection between the motor and the bus port/bar that I am missing?
Anyone had a similar issue?
Thank you for any troubleshooting help.
