How do you all keep your twins straight when trailering.
Yes I know it doesn't hurt them to flop to one side but I like to have them stationary and straight.
I pull my boat around 300 miles one way (usually) when I use it.
I have tried the following:
-Tying the wheel (with hydraulic steering this holds for about 100 miles...then...flop.
- Tethering each tail to the transom ...same result.
- Putting section of heater hose around hydraulic cylinder arms...after a few miles it pops off and...flop.
I have been thinking about a couple of ideas, I know they have commerically plastic snap on clips that go on the cylinder arms and I have made some out of 3/4 pex and it snaps on and holds great but I am afraid of it causing damage to the end caps of the cylinder (see pic). I also thought a large flat rubber washer on the cylinder end could protect it but how much force would be placed on the cylinder during trailering?
Then I also contemplated a pex rod from the port engine tiller to the swim platform handle which would hold everything in place, but again how much force would the tiller take during trailering? (see pic)
Any ideas?
Any ideas?
