Hello.
First, I wanna thank you for allowing me to become a member of this group.
My problem: I just wanted to drain the VST. The motor is a F80 B 2007 Yamaha. Last time when I did it I had to push the valve from the top of the VST in order to allow the fuel to flow.
This time it was not the case. The VST was drained without pushing the Schrader valve. I just unscrewed the screw from the bottom of the VST.
Question: is it normal? Do I have to worry about it? I have no visible air leak in the system.
Thank you in advance for your advice.
