Okay after looking at tons of threads, and researched all over the net. Can someone please tell me if I can install a water temp sensor on 2001 yamaha V150TLRZ. I've seen people saying mount on top head, mount here mount there.... water pressure is mounted on top the starboard side of the head. There is a bolt on top the port side head , is that where I would install one? Yamaha doesn't have the option part for this or I just over looked it. Can I use a aftermarket one? Any pix of where the sensor should go would be greatly appreciated. Thanks
Water or head temperture sensor help!
Being that it's been installedI need to move the water pressure sensor, ok
What part do need to buy for the temperature? I don't see any listed for my motor
Oops. My bad. Wrong catalog.
688-83591-00-00
Page 4-13
https://yamahaoutboards.com/catalog/2017/MRP/index.html
Thanks , so just to be clear, I can order the sender , screw in in on the top of my motor and hook to any temp gauge? Are do I have to get the Yamaha gauge? Asking cause I have a gauge I bought to match my other gauges
I would think it depends on what the gauge you have needs to work properly.
we have no idea what you have
Black sterling, it only came with the gauge. sorry I guess I should've mentioned that.
SeaStar Solutions
The thread size for the hole/plug in the head is M14 x 1.5
Yamaha sells a temperature sender for their analog gauges that is a direct fit - but as pointed out above -
that sender may - or may not - work correctly with your Teleflex gauge.
Teleflex lists senders for your gauge in several NPT threads:
what you certainly could do, is use the 1/8" NPT Teleflex sender, and obtain an adapter bushing to take it up to the M14 thread.
Yamaha sells such a bushing (intended for their analog pressure gauge)
seems you need to look for what works with your gauge you purchased
For Sender information refer to the SeaStar Solutions Sender Code data
sheet or visit the SeaStar Solutions || a global supplier of marine equipment for sports and leisure boats.
If that old 14mm bolt doesn't want to come out of your head, you could drill and tap it , in place, for that 1/8"NPT sender that's compatible with your gauge
Originally posted by 99yam40 View Postseems you need to look for what works with your gauge you purchased
Originally posted by scofflaw View PostIf that old 14mm bolt doesn't want to come out of your head, you could drill and tap it , in place, for that 1/8"NPT sender that's compatible with your gauge
but on my F225TXRD those plugs are stainless steel - not my favorite metal to tap...
Originally posted by fairdeal View PostThe thread size for the hole/plug in the head is M14 x 1.5
Great thanks for the info! Ill try that out
ÂÂÂÂÂÂÂÂÂÂÂÂ
