Hi just bought a Yamaha 2013 F150XA 4 Stroke i need suggestions on a complete rigging set i want digital gauges but don't need the most expensive ones. I only have engine nothing else no prop either. Different combinations would be appreciated. Thanks
Riggings
So Page 10 - which has a detailed parts list at the bottom:
http://yamahaoutboards.com/catalog/2017/MRP/
Sounds like the conventional round multifunction tach is all you need. If monitoring speed is important to you then add the speedometer/digital fuel management gauge.Originally posted by Buddbud7810 View Posti want digital gauges but don't need the most expensive ones.
New and used conventional round gauges can be found on ebay. New cost between $225-$300, used $150-$200. This website, GaugeSaver.com – LCD Gauge Restoration and Repair, refurbishes used round gauges for resale. They look brand new and only cost $50 + shipping.Jason
Riggings Setup
I have found the setup i want Single Engine with Binnacle Controls - Command Link
1 Premium 704 Single Engine Binnacle Control Box
704-48205-P1-00
1 Single Engine Key Switch
704-82570-12-00
1 Command Link Round Two Gauge Kit
6Y8-0E83R-41-00
1 10 Pin Main Harness
688-8258A-60-00
1 Main Buss Harness, Rear Hub To Front Hub
6Y8-82553-21-00
2 Pigtail Harness, Front Hub To Gauges
6Y8-82521-21-00
This is what i found any suggestions or changes i might need just let me know please and were i can purchase at a great price tried boats.net but most of the items did not come up. Does the fuel/speed gauge have fuel management in it. Thanks
Did you use the service Jason?Originally posted by Jason2tpa View Post.... This website, GaugeSaver.com – LCD Gauge Restoration and Repair, refurbishes used round gauges for resale. They look brand new and only cost $50 + shipping.
I believe it is a good $50 service, but they are hardly "good as new".
A compromise.
Like having your plastic headlights restored, there is a remarked improvement.If its got teats or tires, you bound to have trouble with it....
