Hi everyone...I'm working on my neighbors 2006 Yamaha 8 HP T8ELH .... Manufacturers date code is February 2006.
I believe the serial number might be 1011863 as that's what's on the white sticker next to the model number T8ELH....There's also on the sticker 60S and an L.
The engine has always kicked up when put into reverse gear from new under acceleration....Neighbor never gave it much thought and he just pushed the engine back down by hand and just let the engine idle slowly while in reverse each time thereafter once the shock of
went away....The engine is on a 22ish-ft sail boat and the boat is on an easy lake/marina to navigate.
Right now the engine is off the boat due to the impeller losing 5 of it's 6 blades and was getting very warm and barely shooting out water.
So with the engine home, we're now trying to figure out why the engine didn't want to go fully down into the locked position.
At our first look it appeared the main engine vertical portion wasn't aligned properly to the center of the 2 side mounting clamp brackets....Item numbers 1 and 2 in the parts link below.
The engine was hitting on the starboard side clamp bracket as you lowered the engine probably a bit over an 1/8 of an inch it seemed like.
All the horizontal engine bolt clamp brackets were tight. But between loosing the horizontal bolts to the mounting bracket and a bit of grinding to the aluminum brackets, we're now able to get the engine to go down in-between the mounting brackets but there's now another issue once the engines almost all the way down.
The side mounting brackets have 3 open groove "catches" to help position the engine in an upwards position for out of water type storage.....As you lower the engine after releasing the black tilt release lever, the engine wants to stop in the lowest storage position and won't go all the way down to lock on the tilt pin rod.....That is until I manually reach up by hand and pull further outwards on the receiver assembly (which will be item 26 in the parts link below) Then I can bypass the lowest storage position and lock the engine down on the tilt rod/pin.
Because he says it's been happening since he bought the engine new in 2006, My guess was there may have been some type of service literature/bulletin regarding an issue similar to this that might be found within a Yamaha dealers only communication network/website under their service literature section something like Mercruiser has in their dealers only website....Or I guess it could be on paper too? If one exists.
I'm hoping either someone recalls seeing this issue in the past or would be kind enough to have a look through the Yamaha outboard service literature and see if there might be a written recommendation someplace out there.
Here is the parts guide for the area I'm working on with this engine model.
2006 and Later T8ELH Yamaha Outboard BRACKET 1 EH Diagram and Parts
Here's the complete engine model parts guide if needed to help any. 2006 and Later T8ELH Yamaha Outboard Parts
Sorry if this seems long winded to get to the main issue at hand.
Thanks Everyone.....Much Appreciated.
