Helping another identify his engine year and model. All I know is it's a 200hp V6 carbureted 2 stroke. The numbers I can make out on the plate are 0V48 (or 0V46) and 300116. Important to note...the owner says the ID plate may not be for this engine. You can see from the pics the engine was stripped, painted, then reassembled. Other than the ID plate, is there anywhere else on the engine where identification numbers can be found?
