Well I didn't get the LU off as I was working with the rats nest of wiring to wire up the. Ew digital speedo and analog temp gauge.
I did take the shift linkage off, find neutral on the slide and began adjusting. When I got to the VERY last "shortening" adjustment it fell easily onto the slide. And then while the engine was running it would easily go into reverse and forward. The binding stopped. From forward it was easy to neutral, from reverse it would actually go into neutral, but almost not far enough. I would hear a very subtle clicking.
I wonder if I adjust tighter at the binnacle if I can get that last bit out. And now I'm wondering if the LU damage was simply caused by bad shift cable adjustment.
