Bought a boat that didn't get used very often. Then after running it for 20hrs or so one of the engines starting sputtering and losing rpms regularly. I could pump the fuel ball and get it back and running. Eventually it got worse and the the second engine started doing it. Can get them to run but eventually they just bogg down. It happens in high and low speeds. Not sure where to start. The fuel water separator and fuel filter are not old, but I think the problem is elsewhere. Both check engine light came on the last time I ran it and barely made it back to ramp after pumping bulb and starting over and over. Would run for a min and then stall out. Any direction and advice would be greatly appreciated.
Fyi the engines only have 100 hrs on them and they are 2011
Just like Petersons, mine and as I re-call, your F150
