I finally got a new used lower unit, and swapped everything over. I had the flo torq iv on my other lower unit because it chattered really bad at low rpm with my q3 15.25x13. I think I put it on correctly, tappered part of the thrust washer towards the shaft so that the shaft would fit in it and then the prop and flo torq and then tightened down the nut. I didn't put a torque wrench on it, but it seems looser to me than it did before. But I can't remember. I went out and still hit 5200 rpm and 32.5 mph which is the same as before, but I feel like there's a little vibration at 1100-1500 rpm. I have a video attached. The weird squeaking noise is the prop touching a leaf. I spun it backwards first and then forwards the second time, and pulled it in and out and then a little side to side. It doesn't seem like the shaft is moving though?
https://photos.app.goo.gl/lja1Zu2eigx0ljx33
