Lower Unit bolts
  • Kirk Gibson
    replied
    Grease yes
    Oh yes RB, when I can get this thing to go back in...lol...I will for sure be using grease on all the bolts. I really appreciate all and any help.
    Leave a comment:
  • Kirk Gibson
    replied
    Thanks RB
    As for the shift shaft splines, when I lowered the spacer plate a little I can see the SS rod coupled with the female connection from above and when I raise & lower the LU just a little bit it slides up and down in that connection like it is aligned. The controls and LU are in neutral.
    I am really curious about what is causing this. I am about to go out and take it all back out.
    Leave a comment:
  • rodbolt17
    replied
    are you sure the shift shaft splines are lining up?
    typically that is the issue.
    I have done this work here in the salt pond since 1989.
    I have greased all the fasteners for lowers and water pumps for Suzuki,tohatsu,J/E,mercruisers mercurys mariners yamahas and Hondas and force motors and Chryslers and some others I don't even remember.
    never had one come off never used a torque wrench as most the fasners you cant get to with a torque wrench.
    I have worked for more than 1 dealership and done my own since 1995.
    Leave a comment:
  • Kirk Gibson
    replied
    Yes
    Yeah, I don't see how anything would have gotten in that hole in such a short period of time. I dropped it, put it on the bench, came back next morning, installed the pump and went to put it back in. I greased the DS bushing also before going back. But if all else fails I will take it to the local dealer here at the lake and have them stab it. Its a first for me to have to do that.
    I am going back out now to repull it and I will definitely check ... heck maybe a chipmunk ran up there overnight or something.
    Leave a comment:
  • 99yam40
    replied
    I would check to make sure there was nothing in the hole the drive shaft is going up into
    Leave a comment:
  • Kirk Gibson
    replied
    It's official
    Well, I have done many stern drives (merc alphas & omcs), other outboards (Evinrude, Johnson) and also these 2 yammies about 3 years ago. But now it's official, this time, on this engine, has been the biggest PITA of them all! ...lol
    Re-pulled it, regreased everything, restabbed it, (verified by eye that the shift shaft & water tube went together. But it stops at about 3/4" of going all the way in.
    I have been using the strap method and keeping it aligned perfect. When it stops I can turn the flywheel and I notice that it turns the drive shaft below but I'm afraid it isn't going in the flywheel (what else could it be?) so now while it is hanging I (my wife) will try and turn the flywheel while I hold the drive shaft with a pair of channel locks from below and hope the splines will suddenly pop into place. I really don't want to try and pull together the last 3/4" with the bolts...it should go all the way up like it did last time I'm just wondering why this #%*##^ is happening this time.
    Leave a comment:
  • Kirk Gibson
    replied
    Some clues
    Well after a couple of more attempts I decided to drop the spacer down a little to actually put eyes on the situation. Loosened the 6 bolts (didn't remove them) and dropped it down about a half inch ...then I could see everything. The shift shaft is aligning and going in every time!!! The water tube is going in great every time!!! So that should only leave the drive shaft not going in. I greased the splines (although lightly) and, no, never anything on top. I was able to turn the flywheel by hand but still nothing. I may have to pull it down and regrease (more heavily) the splines ...guess that will be my next move. At least I know it isn't the shift shaft or water tube. I will run one bolt on the spacer back up for now and if it hangs up at least by just loosening that one bolt I can quickly check the shift shaft or water tube.
    Just an update.
    Leave a comment:
  • 99yam40
    replied
    No. I googled proper hole and got worried about going to hell...
    you were suppose to google hand basket, you pervert.
    but here is what you were asking about I think
    http://www.phrases.org.uk/meanings/h...andbasket.html
    Leave a comment:
  • Kirk Gibson
    replied
    Uh what?
    I wouldn't touch that line with a 10 foot shift shaft! ...lol
    Leave a comment:
  • pstephens46
    replied
    Leave a comment:
  • 99yam40
    replied
    This place is going to hell in a hand basket.
    What's a hand basket anyway?
    did you try googling it?
    Leave a comment:
  • pstephens46
    replied
    Leave a comment:
  • 99yam40
    replied
    I would think they could easily understand moving it around a little to get it into the proper hole
    Leave a comment:
  • Kirk Gibson
    replied
    Oh yeah
    Yeah, I may get her out there and try and show her what to do. She can do that Im sure ...but no lifting... I think a stiff wire with a hook on the end could make it easier to jiggle that around while I up and down the lower unit until hopefully it goes in. If not I may try the template idea.
    Leave a comment:
  • pstephens46
    replied
    I take the damn prop off now just to lighten a little...
    You have a wife? My wife moved the shifter around enough to "get in" after I explained in detail what needed to happen.....
    Leave a comment:
