so I want to "see" the cooling water pressure (we don't need to get into why)
rather than remove a plug
(tried and stopped, as removal torque approached scary level for aluminum threads)
I Tee'd into the hose running to the fuel cooler from the back bottom of the block. Its easy to access as it passes the port side
But I'm seeing low single numbers - not even 3 psi at a fast idle (~1400)
barely got to 5 psi pushing the boat at 4000 rpms!
I assumed that would be maximal pressure as the water first enters the engine - am I wrong?
or do I have wimpy water pump pressure? bad PCV?
engine temperature is fine, never gets above ~195
[/url]
[/url]
