I have a 1998 VMax that is out of whack. I cleaned the carbs and jets but now my settings are out. Short of buying a sync meter, can someone tell me what the initial settings should be. Thanks a lot!
Carb Settings
All of the set up procedures are described in the applicable service manual. Too detailed to provide here.
Idle mixture screw setting
Ignition timing
Carburetor linkage adjustment
Idle speed adjustment
Pickup timing adjustment
There is no procedure for synching the carburetors to each other via a manometer/vacuum gauge if that is what you are thinking.
LIT-18616-01-87 YAMAHA C150W/S175W/L200W SV
Originally posted by amahaork View Post1-3/4 initial plus minus 1/4. For the starboard carburetors.
3/4 initial plus minus 1/4 for the port carburetors
Set it and forget it.
If you need to play with carb, you have other problems. Timing? Just buy service manual.
Thanks to boscoe informing us of the website where he gets engine schematics, this same website also offers free service manuals.
Not all SM's are offered, but many are. The OP is in luck because his SM is offered. So here ya go bud. Download the manual from the link below. The carb time and sync procedure is detailed in this manual.
https://www.vansoutboardparts.com/se...175w-200w/fileJason
Originally posted by amahaork View PostHe should buy it, like we all. Don't get used to free stuff, bad for morality.Jason
Given that these publications are not supposed to be publicly shared without compensation to the author (Yamaha), the link should probably be deleted.
Only those with valid, paid for paper publications are entitled to download the electronic version at no charge - at least that's my understanding.
ÂÂÂÂÂ
