Guys - I have a 2002 Mercury 115 (effectively a Yamaha F115). EFI, 4-stroke, 4 cylinder.
The SELOC manual that I got for it, states something to the effect of, "Yamaha/Mercury do not release test specs for their sensors - good luck troubleshooting them."
My motor is having these symptoms:
Starts and idles without a problem.
When revved up, often dies as soon as it comes out of idle. When I feather the throttle really slowly, I can sometimes get it to rev up. With some recent troubleshooting, it seems to do more or less OK in my driveway. However, when taken on the lake and under load, the motor was having trouble exceeding 2000RPM.
- I've checked fuses.
- I checked fuel pressure at the rail - getting consistent ~35psi at idle and ~40PSI at WOT (when not in water).
- Got it fresh gas from an external tank, without much change.
- Changed the small fuel filter in the clear water separator housing.
- Changed plugs.
- Checked compression and leak-down.
Then I started looking into the electronics. Lack of OBD-style diagnostics, or data on how to test the components is hampering this effort greatly. Noticed that when I disconnected the Manifold Air Pressure sensor, the engine actually seemed to run much better. Figured that the computer, ignoring the MAP input and using TPS to guess at the fuel delivery was doing better at injecting, so figured that the MAP was bad. Replaced MAP sensor (week in the mail and $120) - virtually no change! Then tested the engine with MAP connected and TPS disconnected - again engine runs better. WTF?
One strange thing - when I disconnect the vacuum hose from the fuel pressure regulator, engine idle (which is usually smooth and good) starts running like crap. Plugging the hose with my thumb, returns it to normal. What does this mean? My understanding of MAP-based systems is that a vacuum leak into the manifold should not make the engine run rough. If anything, it should increase the revs, as the MAP ought to see the drop in vacuum in the manifold and the computer ought to balance it with more fuel. This is however, NOT happening. Certainly, fuel rail pressure is jumping up when I do this, but I don't think that it's a major problem (making things run a little more rich) because when plugging the hose with my thumb, the idle turns smooth again.
This tells me that one of the sensors required for the computer to do its job, is sending bad data. However, without an OBD scanner, or ohm-meter test procedures, I am at a loss on how to troubleshoot this without just semi-randomly swapping in sensors (which is going to get pricey).
Im in Seattle. Any ideas highly appreciated!
PS: one other and probably unrelated thing... I think my stator is going out. I would expect that when the motor is running, my voltage to be at 13-14v. It sits around 12-12.5v. I do not think that this is related, as I have a brand new battery and a charger connected to the system when doing all of this testing. But in the event that the computer is somehow wired through the stator...
- Changed plugs.
