Hi everyone,
I've read several posts related to fault code 28 on Yamaha outboard engines but none of the solutions seems to be applicable in my case.
I'm experiencing a fault code 28 which is related to the swift position switch. As a result of this, I can't rev the engine higher than 4200 RPM.
I've disconnected the wires that run from the switch to the ECU to test the switch function. The switch works the way it's supposed to. I've also tried alternating between gears (forward, neutral, reverse, etc.) and the switch does not get stuck in a wrong position.
When I reconnect the wires to the ECU, I get the error code again.
Would you guys have any ideas on what the cause of this may be?
Thank you in advance.
