I have a new motor only done 115 hours and it has the overheat alarm coming on when idling for about five minutes. This has only started since the 100 hour service when the water pump impeller was replaced. The motor appears to be pumping water a steady stream from the tell tale hole. Engine Model is F150XB.
The engine temperature gauge is sitting at mid range.
As suggestions as to what could be the cause would be appreciated.
