I have a 2017 250 SHO that keeps cutting off once I get over 4k RPMs.
Just dies completely and squats. Engine fires right back up and off I go.
Will take in for warranty work but wanted to check here if anyone had a suggestion for what to look for.
- Checked the fuse box (fuel pump specifically) all good
- Checked Primer bulb, it functions fine
- Checked for kinks in fuel line, none
- Removed fuel water separator to check for obstructions, none
- Filter on engine appears clean and full, didn't remove
Thanks in advance.
C-note
Thanks in advance.
C-note
