I bought a 6AW-8366B-00-00 cooling water pressure/pitot speed sensor
it was a used part - cheap - with no representation that it was in working order.
Turns out - it was not - apparently shorted internally -
connected with a 5 volt reference feed, "blue to black" read 4.83 volts.
Interestingly - with that "output" - the F225txrd ECU refused to recognize that it was connected.
But - I now knew that the oil pressure sending unit used the same connector
So, foiled in experimenting with 6AW-8366B-00, I proceeded using the oil pressure unit.
With some interesting results.
First - using the prepared regulated air pressure test setup -
I compared the "Command Link" (NMEA 2000) oil pressure output values
to a bourdon tube gauge:
just about dead nuts (its a new gauge, but certainly not "NIST traceable")
more to follow
more to follow
