Right of the bat I see 2 TPS codes at 1659 hours, which happens to be the same hours on the engine, might start there.
Yamaha F250 High Idle Help ........
Still got the problem
Well an update.....
Purchased a used throttle body assembly from eBay that matches mine. I replaced the top portion of the assembly which is held on by 4 bolts and that has the 2 electrical connections on it. Figured that was the problem. Well it wasn’t, still has a 300 rpm higher idle than the other 2 motors.
Is there any reason to replace the entire throttle body assembly?
Thoughts?
myself?
I would go to the bank.
get $500 in quarters.
toss a gallon bucket of quarters at it every 30 min until the issues clears.
or grab a multimeter and the SM and find the issue.
typically if the ECU is not happy with an input it sets a higher than normal idle speed. could it be a sensor suffering an IN RANGE failure?
possible.
