Help
  • Help
    IMG_1042.jpgWas removing stubborn oil filter on f115 and accidentally hit a hose just to the rear of the filter. The hose was connected to what looks like some sort of bronze fitting attached to power head. Sheared off the top of the connector where hose connects. Any ideas what this part is and how to fix? Thanks.
    Most responses on here will need to know the year and full model F115---- for an accurate response.
    Dennis
      It's a 2014 F 115 XA. Thanks.
        here's your pic rotated - its the exhaust cover - so water, in or out -
        maybe where the flush hose connects?
        Boscoe or Rodbolt will be on this like a dog on a mailman...
          2006 and Later F115XA Yamaha Outboard CYLINDER CRANKCASE 1 Diagram and Parts
          These diagrams are SO bad
          Part 17? 10 bucks?
          I think they are pressed in according to Rod. And I think he said loctite 518 to reinstall?
            Check out item 17 in the attached file
            You can find this listed under your year 2006 and later and engine model on the parts area of this site cylinder crankcase 1
            Dennis
              Part 17? 10 bucks?
              maybe.
              "with all due respect" our hosts here have a very sub-standard parts "fiche" system.
              lumping everything post-2006 together is really not acceptable.
              and the graphic quality is "the pits"
                That does look like it. Thanks. Any tricks on removal and reinstall. Appreciate your help. Thanks again.
                  How so?
                    Sorry, I didn't spend $49 on snagit as you did. Because I knew you already had it! So for the 99.9% of the rest of us, the diagrams SUCK!
                      maybe.
                      I have been meaning to send boats.net an email about this. Not sure why they don't list all of the models and why what they do list has such a degraded image. Not like them at all IMO.
                      Three images below from three different sources. All of which originate from Yamaha US.
                        Actually, there is something wrong with the boats.net site IMO. There is another site that has much clearer images. With a zoom function as noted.
                          Fair enough. Hard for some also to visualize parts installed on the opposite side of motor from the perspective of some of these drawings. Not sure if that makes sense. I guess the alternative would be to go the way of Suzuki and have 69 diagrams to choose from. I guess people get accustomed to whatever they have to work with. With Yam, not so much.
                            one thing I like about the boats.net site: the search function
                            put in a part number and get a comprehensive "where used" list
                            (constrained of course by the ">2006" idiocy)
                            I wish the yamahaoutboards.com parts had that
                            (or if it does, that I knew how to use it)
                              use some vicegrips , twist and pull out.
                              just tap back in
