Yamaha 2-stroke 200 HP GETO L 500430 X 61H with enige noise /vibration.
Both cold and warm, the engine was making a ratteling noise at a certing higher rpm, lower or higher rpm resolved the noise. Now it's making the same noise at weakboaerd speed . Does anyone have idea;s how to analyse this issue and to know if it is bearing, piston, crankshaft related? The engine can smoke heavy after a cold start and warm when starterd whithout throtle. it's gone in seconds but it look it run rich on oil. No thoughts on running on less then 6 cylinders. Anyone for the settings of the oil pump. Anyone suggestion for the maintenace of the fuel pump . reed valves?IMG_0364.jpg
