Originally posted by boscoe99
View Post
Anyone know what this spring goes to?
Wish there were more simple (and inexpensive parts) as well.Originally posted by pstephens46 View PostIt looks far too simple for Yamaha. Why not use the $300 hydraulic version that will break when you look at it sideways?
Being its just tensioning a belt for a fuel pump, it's NOT a super critical part if it skipped a tooth. Heck it's been running without it for sometime now...
Now the hydralic, fancy tensioners for the VALVE CAM SHAFTS, those are critical. Obviously you don't want it to potentially jump one tooth. The dampening with these tensioners, helps keep the belt tension more steady.
I never took one apart, however, it's going to be much more stout than a simple spring which can (and DID) break...Scott
Are we talking about the tensioner or the drive belt. The tensioner uses a spring to keep tension on the drive belt. The cam shaft drive belt.Originally posted by TownsendsFJR1300 View Post
Plz point me out a CAM SHAFT. There is NO cam shaft for this set up.
It is not a cam shaft, it's a ROLLER tensioner that uses a spring.
This ain't brain surgery.
The cam shaft that activates the fuel pump. I point out to you the illustration depicted below.
Then check your brain into the surgical department for an adjustment. Gotcha!
Speaking of parsing, let's parse the belt. The V belt. The cam shaft drive belt with all of the little V shapes that interface with the V's on the drive gear and the driven gear.Originally posted by pstephens46 View PostWell if we want to parse words, the belt is titled in diagram as the "V Belt"
A cam shaft is not a cam shaft is not a cam shaft. A V belt is not a V belt is not a V belt. A Yamaha is not a Yamaha is not a Yamaha. As one might think of a cam shaft, a V belt or a Yamaha.
Isn't this fun? With Yamaha you got to think outside of the box. Keep on thinking. Remember in Asia what we might think of being vertically oriented was always told to me as a kid as being horizontally oriented. But they are not Orientals. They are Asians. Being politically correct that is.
You CS jr?Originally posted by boscoe99 View PostAre we talking about the tensioner THE SPRING THAT ACTIVATES THE TENSIONER or the drive belt. The tensioner uses a spring EXACTLY to keep tension on the drive belt. The cam shaft drive belt.
Then check your brain into the surgical department for an adjustment. EXCUSE ME???
Gotcha!
The SPRING, that's what the thread is about, (read THE first post).
The spring simply puts tension on the belt, PERIOD.
Try staying on topic...
And I don't really need the condescending smart a$$ remarks..
Perhaps your *****ing...Last edited by TownsendsFJR1300; 06-20-2017, 11:39 AM.Scott
Actually, the belt DRIVES a cogged pully. The pully is attached to a cam shaft.Originally posted by boscoe99 View PostPut the crack pipe down and step away from the computer!
WTH?
It is a two stroke. The belt drives a cam shaft. It is a cam shaft drive belt.
In either case (as you seem to like playing with words), the SPRING, simply activates the tensioner.Scott
Well if I called my local Master Tech and asked "Tim, I need a camshaft drive belt for my Z200 hpdi, he would immediately tell me the engine has no camshaft." And then I would correct him. He might be irritated and say "why didn't you ask for fuel pump belt in the first place".Originally posted by boscoe99 View PostSpeaking of parsing, let's parse the belt. The V belt. The cam shaft drive belt with all of the little V shapes that interface with the V's on the drive gear and the driven gear.
We should stop using terms for parts. Creates too much confusion. Only part numbers. But now that would be a problem too as many of those have been superseded. What to do? Assumptions have to be made. Arguements ensue.
I have a cam in my shifter in my car. At least that's what I call it other than a POS on bad days. It goes clunk when I shift. Secured by an M3 screw. Too damn small, comes loose and jams the thing where I can't shift. I said f it and used a little blue loctite.
Very true, BUT the thread is about one part, what is it?Originally posted by pstephens46 View PostWell if I called my local Master Tech and asked "Tim, I need a camshaft drive belt for my Z200 hpdi, he would immediately tell me the engine has no camshaft." And then I would correct him. He might be irritated and say "why didn't you ask for fuel pump belt in the first place".
It's very simple. It goes to the belt tensioner, (both in the pic and the link-which shows the parts #, where it goes and most importantly, how to get a replacement).
The BS with Fuel pump cams, etc, is that, BS..Scott
Someone needs to get a sense of humor.
The third post in this thread described the spring. That should have closed this thread.
It was not me that brought the issue of no cams and no belts.
"Its a two stroke, NO cams/ cam belts." That was brought up in post #10. Why? I have not a clue.
But since the topic of no cams or no cam belts was raised it was appropriate to correct the record. This particular model does use a cam shaft and a cam shaft drive belt.Last edited by boscoe99; 06-20-2017, 12:45 PM.
my motor has a fever.
it is all about the jinglish.
the above motor does have a camshaft.
however it is part of a sub assembly.
the tensioner is not automatic it is manual.
most posters are nuts and have never actually used the tensioner.
*Where is the MANUAL adjuster for the tensioner?Originally posted by rodbolt17 View Postmy motor has a fever.
What does this mean? they remove them, disconnect them, ?
.Scott
