Hi Guys,
Could use your advice.
2006 Model F250 TXR Serial # 6P2X1004882
My engine is stuck in the half up position.
Neither the switch at the helm binnacle nor base of powerhead moves it.
With the hood off, I can hear clicking when the up/down switch is triggered.
I can also feel the relay vibrate when it clicks.
I checked and I know the fluid level is good in the reservoir.
Last time I raised the engine, the PTT motor sounded "strained". A sound I never heard before. Also, I have twins, and the two motors when raised - the starboard motor always came in second place to reach the top. This starboard motor is the one that's stuck in the half up position.
So - I suppose it is either the PTT Relay or the electric PTT motor on the bracket.
To check - I was thinking of removing the PTT Relay on my port engine and installing it on the Starboard engine. My hope is it is the relay (easy to install) but I fear it is the PTT electric motor on the bracket (Hard to remove and install).
Your thoughts?
Your thoughts?
