Brief backstory: I recently installed a new fuel tank and fuel lines. Prior to this installation, when I go to prime the engine for the first ignition of the day the bulb is always empty. I've heard from others that their bulb remains full, or at least not completely empty. Since installing the new tank it's taken a lot more squeezing of the bulb to prime, maybe a dozen or so squeezes before bulb begins to fill.
Today was different. I would squeeze the bulb until my forearms were on fire, still no fuel. Eventually for some reason it began to fill, but moments later the fuel would reverse and the bulb emptied. Bad primer bulb?...sure, probably. I bought a new primer bulb, installed. I experienced the same issue. Kept squeezing till it eventually filled. This took about 2-3 minutes of squeezing to fully prime.
Dropped the boat in the water, started, all good. Ran the boat around for an hour or so. Stopping every so often, shutting down, and checking the bulb. During this time the bulb would remain partially full, which is normal.
No fuel leaks anywhere, plenty of fuel in tank, fuel pump functioning properly. Few questions:
* Primer bulbs have check valves, right? They prevent fuel from reversing flow. If this is correct, and the primer bulb is new....what's happening here?
* Fuel pump....are there also check valves in the fuel pump that prevent reversed flow from carb bowls?
* Even though the fuel lines are new, IF there was a puncture in the fuel line between bulb and tank, thereby pulling air instead of fuel, I would notice this fuel leak as it flowed into my bilge. So i'm really at a loss for what's happening, why it takes so many squeezes of the bulb. I had to look at the fuel gauge a few times because it seemed as if the tank was empty. Your thoughts on possible causes and what to look for?
* There seems to be debate on whether the fuel/water separator should be located between the tank and bulb or between the bulb and engine. If someone knows the definitive answer to appropriate location, please reply and detail its reasoning for location.
