02 200 HPDI can't get on Plane
  • 02 200 HPDI can't get on Plane
    I got a late start to the season to add insult in injury, I can't get on plane. A little history about the motor with 255 hrs on it. 2nd year with boat, last year I've had problems with the needle valve sticking if I let the boat sit for 2 weeks (happy wife, happy wife! goes camping). This season, I slightly sanded the orifice where the needle valve sits and pumped 12 gallons of water from the fuel tank.
    I drop the boat in yesterday and take the family for a ride, NOT. As I tried to get on plane, the motor seemed like it was starving for gas. Copy and paste video link from Youtube- https://youtu.be/iVMltvLhiZ0.
    I checked fuel separator and clear plastic gas filter under cowl and no water found. Also changed silver filter above VST tank. Connected YDS system and here is the following report. I have indicated places in file where I think I might have a problem.
    Note: Diagnosis Record - Cylinders 2 & 3 were off. But =- when I revved in neutral to 1500rpm, cylinders 5 and 6 turned off. Not sure if this is okay or not.
    When I did an Active test-cylinder check, cylinder 1 - stalled the engine within 10 seconds of the 20 second test.
    Cylinder 2 and 3 are off - No change in rpm.
    Cylinder - 4, 5, rpm dropped, but picked up, then eventually stalled motor.
    Cylinder - 6, rpm ran fine.
    Save date June 10 2017
    ECM No.: 68F8591A20
    Diagnosis
    Code Item Result Condition
    22 Atmospheric press sensor Normal
    13 Pulser coil Normal
    14 Crank position sensor Normal
    15 Water temp sensor Normal
    18 Throttle position sensor Normal
    19 Battery voltage Normal
    23 Intake temp sensor Normal
    25 Fuel press sensor Normal
    26 Injector Normal
    27 Water in fuel No
    28 Shift position switch Normal
    44 Engine stop lanyard switch Off
    Diagnosis Record
    Total hours of operation 257
    Code Item Occurred
    26 Injector 256.6
    22 Atmospheric press sensor 256.5 - ?
    28 Shift position switch 241.6
    27 Water in fuel 226.5
    Engine Monitor
    Monitor Item Result Unit
    Engine speed 650 r/min
    Fuel pressure (5.0±0.8) 5.03 MPa
    Fuel pressure (725±116) 734.92 psi
    Atmospheric pressure 1258.6 HPa - ?
    Atmospheric pressure 37.3 inHg - ?
    Ignition timing BTDC 4 deg
    Battery voltage (12-16) 13.11 V
    Oxygen sensor voltage (0-1.0) 0.16 V
    TPS voltage (0.5-4.5) 0.63 V - ?
    Throttle valve opening (0-90) 2.6 deg
    Fuel injection duration 1.06 ms
    Water temperature (below 90) 34.5 °C
    Water temperature (below 194) 94.1 °F
    Intake temperature (below 70) 28.5 °C
    Intake temperature (below 158) 83.3 °F
    Electric oil pump Low
    Firing of cylinder #1 Yes
    Firing of cylinder #2 No
    Firing of cylinder #3 No
    Firing of cylinder #4 Yes
    Firing of cylinder #5 Yes
    Firing of cylinder #6 Yes
    Starter switch OFF
    Engine stop lanyard switch OFF
    Over-rev control release lead OFF
    Main switch ON
    Shift position switch ON
    Water detection switch OFF
    Oil level switch (remote tank) ON
    Oil level switch1(engine tank) ON
    Oil level switch2(engine tank) OFF
    Oil level switch3(engine tank) OFF
    Water temp switch (over heat) OFF
    Dual engine system switch OFF
    Data Logger[Engine operating hours according to engine speed]
    Engine speed Time[h]
    - 1000 r/min 69.2
    1000 - 2000 r/min 131.5
    2000 - 3000 r/min 17.7
    3000 - 4000 r/min 30.3
    4000 - 5000 r/min 8.3
    5000 - 6000 r/min 0.1
    6000 - 7000 r/min 0
    Data Logger[Data comparison graph]
    Engine speed[r/min] Fuel pressure (5.0±0.8)[MPa] Battery voltage (12-16)[V] Oxygen sensor voltage (0-1.0)[V] TPS voltage (0.5-4.5)[V] Water temperature (below 90)[°C]
    1000 5.11 13.92 0.69 0.84 38
    1400 5.14 16.48 0.1 0.94 36.5
    700 5.03 14.36 0.11 0.63 38.5
    700 5.07 14.65 0.1 0.63 40
    1750 4.99 13.04 0.05 1.13 39.5
    1500 4.95 16.26 0.09 1.02 38.5
    750 5.07 15.38 0.16 0.63 38.5
    650 4.99 13.84 0.1 0.63 41.5
    750 5.07 13.92 0.11 0.63 42
    600 4.99 13.4 0.2 0.63 42
    650 5.03 13.77 0.1 0.63 41
    650 5.03 12.38 0.6 0.63 26
    650 5.07 12.96 0.17 0.63 34
    I need help to trouble shoot this, before wife want's boat gone. Happy to trade wife for tech support.
    THanks,
    Mikey
    what did you do with the gas that was in the tank with the water?
    was it E10?
    Did you have the tank cleaned?
    I was expecting a pressure reading in PSI
    with that much water there is probably a need to have the VST ,LP & HP pumps, and injectors serviced.
    lots of screens/filters in things
    HPDI motors run on the edge of lean to start out with, running a sick motor can damage it quickly.
    find a Yamaha shop with a master tech to have a look.
    Rodbolt might comment
      was it E10?
      I disposed of the bad gas.
      No, thought the dry tank was good enough.
      YDS produced the report.
      with that much water there is probably a need to have the VST ,LP & HP pumps, and injectors serviced, lots of screens/filters in things.
      I serviced the vst tank myself (very handy guy), and filters associated with fuel lines (silver filter ontop of VST, plastic filter under cowl). Was going to wait until this winter to service injector mysterious filters.
      HPDI motors run on the edge of lean to start out with, running a sick motor can damage it quickly. I hope Poseidon is on my side with this one. I've only owned it 2yrs now and unaware of prior issues. I'm finding out the hard way.
      Suffolk County Long Island, NY. I've been told, Accurate Marine Yamaha are the best.
      Any additional help is welcome...
        that engine is on a submarine.
        look at the baro pressure.
        we need a YDS screen shot at the FAILURE RPM and LOAD.
        that engine in N runs on 4 cylinders at idle and 2 cyl above about 1200 RPM.
        make sure the shift position switch works when shifted into gear.
          Or supercharger has been installed. A lot of boost pressure at idle. What will it be with the throttle opened up?
