Jaja.. very generous your comment on my English with translator .....
I am afraid my connections are fine.
Just use the blue GPS cable with the white of the connection tab. Do not use the ground wire L because the GPS and the 6YC share the same negative for its general operation (I have secured with a tester).
I suspect that the problem could be in the choice of the "sentences" of nmea0183 ...
There are many options available in my Garmin 43dv .... for example, I have not found in my garmin model that indication "nmea imputado support for the DPT , MTW and VHW sentences ".
What do you think?
Thank you very much for the help!
What do you think?
