1998 s 175 TXRW which I have owned for five years has been great today I was towed in by Boat /Us because of an overheat alarm.
1, 2017 new thermostats ,complete water pump used the boat all May no issues today after running 15 minutes over heat alarm ,cooled restarted few minutes alarm.
2,removed thermostats no change few minutes alarm ,called for tow.
3,at the dock ,opened both thermostat housings strong flow of water from hose water to one thermostat housing came out lower unit ,tell tail ,filled other thermostat housing and water came out .
4, Connected hose to flush out connection ,water flowed tail tell ,low unit and out both thermostat housings
5, Started engine tail tell ,low unit and both thermostat housing had water coming out .So what's next.
6, should I use a external thermal reader ? Does the thermo sensor activate alarm or either of the two thermo switches ?
I know what it can be salt in the water passages hoping not . Thanks for any help .
