hi there. i have a 30 mlhr currently i am trying to see if there is anything major wrong with this engine before i switch the power head off of my other motor. i just bought this motor and don't know much about it and the seller was unsure of exactly what was wrong with it other than it doesn't stay running at idle.
so i have taking it home changed the oil and lubes clean the fuel filter which looks to be new.
i hooked up the gas and gave it a few pumps pulled the choke and it started after pulls i let it run for a minute holding the throttle and closed off the choke.
it kept running for a i little bit so i switched it into gear and gave it more throttle and every thing seemed fine until i switch the gear back to neutral. it died at idle. i started it again and left it idle until it died again.
i am thing maybe the pilot screws need to be adjusted or possible maybe broken.
any suggestions would be great. thanks
