I can idle fine, get up on a plane and once the rpms approach 3000 the engine looses powers and kinda bogs down until it finally kills. I try to re crank it and it acts like the battery is near dead (which it isn't). Once I able to get it back running it runs with a dead miss. I can go keep it running at a high idle and the second I put it in gear it kills. Eventually I can keep it running and put it in gear and the miss goes away and everything seems fine..... I try to run it again and the whole thing repeats itself.
I have checked the following:
- Fuel pump is OK, diaphragm is good no leaks
- Checked each cylinder by pulling plug wires while idling, all are firing and appear ok.
- Checked compression all 3 cylinders are 110,112,110
- Installed new plugs
- Fresh gas
- Drained fuel from water separator
- Replaced primer bulb
I am starting to lean toward a rectifier or CDI...
Any help is greatly appreciated!!!!
- Fresh gas
