Replacing starter solenoid.
I may be wrong but there should be a positive (red line) to one terminal of the solenoid (hot all the time).
The other terminal, has a line to the STARTER. That would ONLY be HOT when the key is activated (cranking) (by one of the smaller wires-ignition switch).
I'd test the smaller wire to see if that gets 12 volts when in the "crank" position (telling the starter to spin over).Scott
Now your getting somewhere.Originally posted by paddlewave View PostYes. I tilted the motor up placed the bracket down. Pressed tilt down and the fuse blew. And kept blowing. Went through five fuses, before I ordered the new solenoid.
The T&T unit will have an up terminal and down terminal, with one wire on each. (Disconnect the down line and the fuse WON'T blow).
**Start tracing the "down terminal line" backwards(away from the terminal.
it's got a dead short somewhere, hot when activated(down), GROUNDING.
IE, it's grounding directly to the block (or other negative) once you push the down button, blowing the fuse.Last edited by TownsendsFJR1300; 05-27-2017, 06:44 AM.Scott
