I was just reading the Winterization sticky, and I realized I didn't do the recommended step of spraying engine tuner into the fuel injection tubes before fogging it. I assume I can still do this step now to remove any carbon buildup that I might still have from last season. I'm just wondering what tuner people would recommend for a 2011 Yamaha F50 (EFI). Yamaha's Combustion Chamber Cleaner is $8 for a can.. is it worth it, or is there something cheaper that's just as good/safe to use? Thanks.
What engine tuner do you use for EFI outboards?
Are you sure you need to use it?
I use the Yamaha Ring Free Plus with every tank of gas. Never had any issues.
Are you having issues?Last edited by pstephens46; 05-24-2017, 09:20 AM.
No obvious observable issues, except the engine does seem slightly more shaky than normal at idle. But the reason I thought of doing this is because it's on this forum's Winterization procedure. It just seems like a cheap, easy thing to do to prevent carbon buildup. I'm just wondering if there's anything cheaper than $8.
I also treat the fuel, so I assume I don't have much gunk in there to begin with.. but I'm not the original owner, and I'm a big fan of easy/cheap/fast preventative maintenance that can help extend the life of the engine or improve performance.2011 F50TLR, 2010 G3 V167C
ÂÂ
