Hello there,
The engines are 2001 OX66 LX/SX225TXRS.
Is this procedure supposed to be done in the water or is it OK to do it on muffs?
The issue is (or not) after doing a sync of throttle valves, adjusting the TPS voltage and setting the idle speed in the 700 rpm range while on muffs, the engines are down to idling at 500 rpm when in the water. Is this normal?
Thanks in advance!
Thanks in advance!
