On my 2000 HPDI Z200TXR YDS plugged in, saw code 28 so I thought I should test the switch operation. (boat is out of the water, will be in tomorrow)
I monitored the shift position switch signal.
1) Neutral - SWITCH = ON
2) Shift to forward - SWITCH = OFF ( I believe this is how it is supposed to work)
3) Shift to neutral - SWITCH = OFF ( incorrect operation)
4) Shift to reverse - SWITCH - OFF
5) Shift to neutral - SWITCH = ON (back to correct)
6) Shift to reverse - SWITCH - OFF
7) Shift to neutral - SWITCH = ON
physically inspecting the switch, it looks like the black slider does not hit the switch when the shifter is moved from FWD back to NEUTRAL, it sits forward just a bit. While in this position I can click the switch level with my finger, it goes OFF. If I go to REV then back to NEUTRAL the switch returns to ON.
I replaced the switch and slider assembly, same result.
Is there any adjustment on the slider? Is there something else going on that might be the problem?
(side note:When shifting from NEUTRAL to REV (with the switch incorrectly OFF) I thought I would see on click ON then OFF as the slider passed by but did not notice that.)
Thanks for any assistance
