Hello GentlePeople, I have a 1998 C115hp outboard that has been giving me some problems and was hoping someone could steer me in the right direction. I can run the engine up to about 3000 RPMs without any issues. Runs smooth and strong. If i push it over those RPMs occasionally the over heat warning buzzer will come on, the engine runs rough as crap but after letting it idle for a few mins or turned off i can run it below those RPMs all day.
the "pee" stream is strong so i believe the water pump is good although I have no replaced it in a couple years.
Question is.......... before i start throwing parts at the engine what could be causing this over heating?
Thermostats?
Poppet Valve?
Impeller?
obstruction somewhere?
dirt?
Gremlins?
thanks for the help.
Thermostats?
Poppet Valve?
Impeller?
dirt?
Gremlins?
