I own twin 115s, F115XB and LF115XB, the counter rotating engine prop spins when it is in neutral, the dealer that installed it said that that is normal. I was wondering if this is normal or is there a way to stop it from spinning, like an adjustment or something that needs to be done.
prop spins
Completely normal. Some propellers will turn fairly quickly if and when the motor is being run on flush muffs. My Yam F200 propeller turned quickly. Fast enough that I did not dare try and stop it. But if the propeller were prevented from turning before the motor was started (say it was held by a stick) then it would not turn.
The gear oil is being rotated by the gears spinning within the gear case. The turning oil then acts on the propeller shaft to turn it. The propeller being attached to the propeller shaft is going to turn. Sort of like what happens in an automatic transmission.
If you are not familiar with the innards of the lower unit, take a look at this video.
https://m.youtube.com/watch?v=hYPuB9nmS8E
Originally posted by boscoe99 View PostCompletely normal. Some propellers will turn fairly quickly if and when the motor is being run on flush muffs. My Yam F200 propeller turned quickly. Fast enough that I did not dare try and stop it. But if the propeller were prevented from turning before the motor was started (say it was held by a stick) then it would not turn.
Originally posted by 99yam40 View PostI believe Bosco was referring to the torque converter on automatic transmissions.
that is the device that transfers rotating energy thru fluid /oil
but that does lock in mechanically once up to speed
https://youtu.be/z5G2zQ_3xTc
Originally posted by panasonic View PostYes it does through the lock up clutch in the torque converter, once it reaches a certain rpm.
No to sure of boscoes 49 Buick had one though, but I bet he will soon answer that.
A couple years ago, I asked the same thing on this forum. This is the first engine that I have had where the prop spins VERY quickly in neutral (I'm used to seeing some spinning). But mine spins so fast it looks like it is actually in gear. However, I can physically stop it.
But I asked the same question you are and got the same responses. Very normal. The super fast spinning in neutral apparently isn't as common, though.
Sorry for getting off topic - I realize this thread is more about cars and TC's...2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostA couple years ago, I asked the same thing on this forum. This is the first engine that I have had where the prop spins VERY quickly in neutral (I'm used to seeing some spinning). But mine spins so fast it looks like it is actually in gear. However, I can physically stop it.
Was LU ever taken apart for repairs in the past?
ÂÂÂ
