Good morning folks,
I, being the helpful bloke that I am, have been assisting my neighbor get his newly acquired 2005 Caravelle Key Largo center console boat ready for his introduction to Florida inshore boating.
It is powered by a 2005 Yamaha 150TXRD (carburetor). 1st was to get the engine to crank. It turns out that the factory battery wire was internally corroded and just not letting the starter turn the engine over due to the high resistance of that wire. Fixed. The engine starts, idles, runs and looks great.
After a half hours running easy in the river, we got up on a plane for a minute or so before we experienced an unexpected loss of speed/power. I pumped the bulb and it went flat (internal suction/ restriction)
Now, after changing the spin on fuel filter, I am still noting a restriction in the fuel hose from the installed tank to the filter housing. I imagined (while working on it at the ramp, in the sun) that floating debris and crud had the pickup tube screed clogged and tried to blow on the hose that is connected directly to the tank that I disconnected from the inlet side of the spin on filter housing. I encountered great resistance, even with the fuel tank fill cap opened so my hot air (breath) could be vented out.
I seem to remember that the EPA or Coast Guard had mandated some check valve so if a boat were to sink it would inhibit the pollution of the waters. I am not familiar with this and I wonder if it could be my problem. A defective check valve?
I have an aircraft fuel pump that I use for transfer and I purchased a sending unit gasket set. I am going to empty the tank and take a look see.
Any advice as to anything else I should pay attention to or check?
