Update: Got the part in for my carb and its all back together and running......
Took a few minutes at home to sync the carbs then headed straight to the lake....
Boat ran great idled no problem at the dock for 15 minutes took it out for about 25 minutes brought it back to an idle no problem.....
Now heres what I have done so far.....
Cleaned and went thru the carbs for the second time, replaced the fuel tank, fuel filter, and spark plugs.....
The only thing I am worried about I was checking the sync out on the water because I know that can change the way the boat runs....Sync definitely seemed in spec but when I "blipped" the trottle it would idle real low and catch itself not sure if this is normal or not, and second is around 2200-2700RPM it kinda misses and bucks but lower RPM or HIGHER boat runs perfect.....Now I tried to make that happen at the dock and it would hardly do it so while it was doing it I tried to adjust the air/fuel screws and it seemed to smooth itself out.....not to sure if I should try the sea foam fuel additive or yamaha ring free.....I just want this problem solved so I can enjoy the summer fishing
I am uploading a video to see what you guys think
https://vimeo.com/217935236
I will get some tomorrow and give it a shot and see what happens!
