Ok, so I ran thw boat today with the fuel pressure gauge attached to the fuel rail and the pressure never went below about 36-37 psi when going in and out of neutral but the motor still stalled when going from in gear to neutral after about 2-3 seconds in neutral. The rpms start to jump around from 500-1000 rpms then dies but all the while maintaining solid rail pressure. Thoughts?
2003 f115 txrb stalls/low idle
Originally posted by pstephens46 View PostQuestion to forum: is the shift position switch the same switch that cuts spark as the motor is shifted in and out of gear? Could that function be malfunctioning?Scott
Solved!!!
Well, just an update. I think I have fixed the idle issue! I bought an injector rebuild kit off eBay and replaced the filter baskets and o-rings. Dropped the boat in the water and ran it for a good 30 min with no stalling in and out of gear. The bottom of 2 filters were gunked up pretty bad. I think I'll go ahead and just replace the filters and o-rings on the starboard side too. I guess only cleaning the injectors wasn't cutting it. Thanks for all the recomendations guys! Tight lines
ÂÂ
