I hit a submerged rock at about 1/3 throttle with a F50 w/ SS prop. Hard enough to dent up the SS prop. I've run the motor a few times since and then decided to spin the prop while the boat was trailered. It wasn't till then that I noticed the prop shaft appears bent.
Is it possible that running the motor after this incident has caused additional damage and if so what?
I'd rather change the shaft out myself since I'm getting "ball park" quotes of around 350.00 and up.
Whats the degree of difficulty and is it even feasable for a shade tree mechanic to undergo this ??
thanks.
thanks.
