My 07 90TLRC started a first time in 2 years, a slow messy oil leak at the end of the fishing season here in KY. It appears to be coming from under the cap, where the low oil sensor is located on the oil reservoir and down the neck spreading down the oil reservoir bottle and into the sump area. Maybe a ounce of oil, more or less. I have removed the reserve tank to cleanup the oil properly and took some pictures of the sensor and tank minus the zip tie that I had to cut. Other than what's showing are there any missing seals I should be aware of?
[ATTACH][ATTACH]DSCN0015.JPG[/ATTACH][/ATTACH]
