I am working on a friends:
MODEL: F15MSHF
S/N: 6AGK-S-1003423
DOM: 12/06
No Service Manual of course
The engine was hard to start and would not idle properly.
I removed the carb and disassembled completely. Tested auto enrichment valve, it extends and retracts. Found pilot jet and enrichment circuit partially blocked. All passages cleaned with carb cleaner, wired out, and blew out with compressed air. Carb put back together, reinstalled on engine. Fired right up and is now idling, but not perfect.
1. Anybody know the idle mixture screw initial setting? It was at about 1 1/4 turns when I removed it.
2. What is the normal idle speed? I have a timing light/tachometer.
3. Is this a 2006 model year or 2007? The owner would like to put a rectifier on it and I want to make sure we got the proper year.
Thanks in Advance.
MODEL: F15MSHF
S/N: 6AGK-S-1003423
DOM: 12/06
Thanks in Advance.
