I have a 2004 Yamaha F150 TXRC. I am looking for a new Coolant Hose Nipple which is located at the top of the outer exhaust plate cover. Yamaha's diagram shows that the nipple is part of the Outer exhaust cover and cannot be purchased alone. It is pressed in and sealed, not threaded in. I read on another thread that a water fitting from a Yamaha T9.9 would fit? does anyone have any information on this? Also what sealant would ya'll recommend to use when pressing in the new fitting? I was thinking a high heat loctite or Gel gasket loctite?
Thank you!
Thank you!
