Im having problem with my 20hp 1981 again.. Now it is taking in water in the lower cylinder. I also did a compression test, the upper cylinder has 100psi and the lower 79 psi.
This sounds to me like the headgasket is broken. But the first thing i'm gonna do is to remove the powerhead, so I have good access to all the bolts to the head. I have tried this before but i'm not sure which bolts to remove?
